« 1 (2)
Re: help!!
From gold coast QLD.
It almost sounds like the starter motor solinoid is earthing out,the battery cables should'nt be smoking,thats a major short!
Posted on: 2008/2/27 7:46
Re: help!!
dat141 wrote:
I'd be fairly concerned if there is smoke coming from the terminals, it takes a lot of current to get things that hot. I'd be checking for short circuits in the starter motor.
A loose battery terminal will ark and get hot and easily melt. When is the most current drawn from a battery?
The hot spot will start at the problem location.
Posted on: 2008/2/27 7:54
Re: help!!
True!
Posted on: 2008/2/27 7:57
Re: help!!
From SE Melbourne
You could go through the steps in the wiki.....they should point you in the right direction.
http://wiki.datsun1200.com/index.php/Engine_Troubleshooting_Overview
Posted on: 2008/2/27 8:56
Mildman, Datsunless
Re: help!!
From Christchurch NZ
Maybe your engine is seized. The heat is building up and causing the cables to smoke.
Posted on: 2008/2/28 7:44
Forced Induction!
Re: help!!
I guess we'll never know
Hope he did'nt burn it to the ground!!
Posted on: 2008/2/28 10:23
Re: help!!
From Wagga Wagga, NSW
ill check the earths and clean the terminals when i have time. ill let yous know how it goes. thanks!!
Posted on: 2008/2/29 0:21
« 1 (2)
