A series 60L 5speed on EBAY
From Sydney
Found this. Might be good for a rebuild.
$200 start bid
LINK
Posted on: 2008/3/5 4:12
Re: A series 60L 5speed on EBAY
From Tamworth , NSW
it sure comes with a tonne of spares.
Posted on: 2008/3/5 8:37
From Christchurch NZ
You'd need to find a new cluster. Or get topgear to make you one..........
Posted on: 2008/3/8 5:28
Forced Induction!
From NZ
Pity it's not in NZ or I'd be very keen on this for my racecar. The damaged parts/gears are both standard 60 series parts.
In simple terms, lathe off the damaged gear from the cluster and weld on a standard one.
Replace the input shaft/gear with standard one.
I've seen this exact same breakage fixed in this way on a 56A 1:1 5-speed. You can see in the picks the layshaft has already been cut/welded.
(Of course this means cutting up a standard 60 series 5-speed but these are reasonably plentyful here in NZ.)
Bob's your fathers brother! One highly desirable, stronger than a 56A, close ratio 5-speed.
Posted on: 2008/3/9 9:54
