coil over mod kits
From gold coast QLD.
Any one know of some one who makes a kit to go over a standard strut?
Posted on: 2008/3/13 10:21
Re: coil over mod kits
From Sydney
http://www.importbitz.com.au/koni.htm
$275 sleave kit when i orded awhile ago also c spanners if ya need em were qouted $22 each
not sure wat struts u got??? for my 120y coupe struts i got(yet to fit)
fh1014
fh2011
fh3011
fh4010
hope that helps Tom
Posted on: 2008/3/13 11:10
From Adelaide, Australia
Im using those ones as well, good quality and weld on. I was going to get the noltec set but they were about $450 through Autosport here in Adelaide so I ordered these ones online instead. I just had drill the spring top hat to suit my koni inserts. (btw they arent koni brand, just made through koni distributors in Australia)
Posted on: 2008/3/13 11:14
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From young
maddat
Posted on: 2008/3/13 11:15
1200ute jelly bean mags
twin 40mm dellortos
From Melbourne Vic
technotoytuning.com
Posted on: 2008/3/13 11:48
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Springwood NSW, Formerly Tas.
i wouldnt go t3 altho they come with springs and are cheap.. if you wanna spend a bit more (who does?) go these.
AJPS Coilovers
pretty sure the t3 sleeve is alloy, dunno how you'd go welding that to your strut :P
both are 51mm
Posted on: 2008/3/13 14:53
1978 120y Coupe.
From Burbank, CA
there is a weldable steel lower part that the alloy sleeve sits on.
those ones in the link are very much like the ones i have, only mine have a single adjuster with a set screw, instead of the jamb nut config, possibly better...
some parts aren't going to be significantly better, no matter how much it costs, basic coil over parts are mostly the same, within reason, not $0.39 ebay honda coil over kits, but stuff from legit sources.
I normally just source those parts from a good racing supplier, if it's good enough for building a coilover for a professional race car, it's more than likely good enough.
Posted on: 2008/3/13 16:03
|||\ 81 KPB310 /|||
From The garage, NZ
Ground control in USA make some that come with springs. They look pretty good to me.
ground control coilover kit
Posted on: 2008/3/13 19:02
Not too shy to talk
From england
what diameter are the standard struts? i've used a kit from rally design in the uk before on other makes with good results http://www.rallydesign.co.uk/product_ ... ath=1358&products_id=3450
Posted on: 2008/3/13 20:10
Thanks guys,this is all great info from all of you.Now the phone calls start
Posted on: 2008/3/13 20:45
