« 1 2 (3) 4 »
Re: anyone used a electric super charger
From Castro Valley,CA USA
You could mount it under your seat to help keep your ass from sweating during a warm day.
Seriously though, that might be a good replacement for my heater blower. My heater fan is kind of weak.
Posted on: 2008/4/2 17:27
You could always run some ducting from the heater blower. Probably work just as well.
Posted on: 2008/4/2 17:29
Love your Datsun.
Treat it well.
From Burbank, CA
anything that flows over 100 cf/m @ 5psi 'works'
it's getting that much pressure at that flow that is why these things don't work...
it would suck your battery dead in like 10 seconds, and take 2 hours to recharge...
Posted on: 2008/4/3 1:49
|||\ 81 KPB310 /|||
From Wagga Wagga
true! well it's done! there is no such thing as a electric supercharger that works!
Posted on: 2008/4/3 3:15
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
From Burbank, CA
it's a beautiful ideal. I WISH it worked, and if you get a blower that meets the specs it will work. it's just not practical, and won't be - the physics of it favor exhaust driven turbos.
Posted on: 2008/4/3 6:17
|||\ 81 KPB310 /|||
From perth
john zappia is fiddling around with something like this
hes using a landcruiser starter running @48volts connected to a large turbo compressor and geared up
cant be run continuously but use like nitrous.because its electric you can use "too big" a compressor and have no lag
not finished but should do the job
having said that its still probably quicker and easier to use a turbo
dazza
Posted on: 2008/4/5 3:38
From perth
with regards to liquid oxygen, it will quite happily use aluminium pistons as fuel
ie: you have created a aluminium powered plasma cutter
this is why nitrous oxide (N2O) is used.
when the nitrogen and oxygen dissociate you burn the oxygen but the nitrogen buffers and softens the combustion
in WW2 they tried everything in high altitude high performance fighter planes and settled on nitrous as the best compromise
dazza
Posted on: 2008/4/5 3:49
From Perth WA
a few years ago i wasted 1200$ on the super double e-ram, electric supercharger. that had a much more impressive web-page with graphs for a lot of cars. there was the single one adding supposedy 2 psi and the double one adding 4 psi, supposedly.
It did nothing at all, a lot of emails back and forth where they said it definitely works on the same engine, and it must be the battery at fault bla bla, in the end I blew it up connecting it to 24 volts to try and get a result!
Posted on: 2008/4/7 5:11
From malta
hey sleeper
i read in the logs the part in which u mentioned the spraying of liquid oxygen.
actualy there is a way in which u can make that without having the need to take a cylinder full of oxygen with you. all u need electrolises and water. my friend read on this particular site that you can even make your car work without fuel only using hydrogen and oxygen produces.
Posted on: 2008/4/7 12:07
From young
Hey all ive jus benn flickin through ebay and found one of these for 33 dollars im thinkin of buying one jus for fun to see if it does anything but drain my battery lol
http://cgi.ebay.com.au/Toyota-Superch ... ZWDVWQQrdZ1QQcmdZViewItem
and another one for 99 dollars
http://cgi.ebay.com.au/Electric-Super ... ZWDVWQQrdZ1QQcmdZViewItem
Appsy1
Posted on: 2008/4/7 12:16
1200ute jelly bean mags
twin 40mm dellortos
« 1 2 (3) 4 »
