L16 gearbox dogleg fit with A15
Quite a regular
From Kedah, Malaysia.
hi guys.. just wondering is it possible to fit L16 dogleg gearbox to A15 engine? if can be done, what are the modification needed? Thanks.
Posted on: 2008/4/4 13:45
Re: L16 gearbox dogleg fit with A15
Sure, what they do is cut the bell off an A-series 4-speed, and weld it to the L-series 5-speed. Dunno if there are other mods needed.
Posted on: 2008/4/4 16:57
From Brisbane, Australia
Put the 2 boxes side by side and start measuring. Will also have to convert the clutch cable/hydraulic.
I have a feeling that the spigot may need attention. There is a differnet spline count, but your local clutch place should be able to sort a plate for you. Otherwise redrill the flywheel for an L series 200mm clutch setup.
When you have it sorted, I'll take 2 kits. Seriously.
Don't forget about the tailshaft.
Speedo cable will fit.
Posted on: 2008/4/4 23:59
From perth
the main obstacle to overcome is getting your gearbox dead concentric with the bell housing before you weld it
if you have a small misalignment you can correct it with offset dowels
dazza
Posted on: 2008/4/5 3:08
Quite a regular
thanks 4 the advice man.. sound like lots of work to do....
Posted on: 2008/4/5 4:42
From NSW South Coast
why not an adapter plate
Posted on: 2008/4/5 7:36
