Browsing this Thread:
1 Anonymous Users
Re: theoritically, what times would a ute with 300hp run? |
Quite a regular
ok sorry i was so vague,
mini tubs, slicks, mini spooled hilux diff, 4.11 gears, 5 speed, heavy duty double plate clutch (single plate clutch when commuting), ca18det with, Microtech LTX8 ECU, external Bosch coil packs, 500hp fuel pump, Malpassi fuel regulator, modified fuel rail, GTR injectors, R31 skyline fuel tank, pod filter, Nitto 38mm external wastegate, turboXS plumb-back BOV, oil catch can, alloy radiator with alloy header tank, SPAL 14
Posted on: 2008/4/18 12:18
From perth
from moroso power speed calculator: at 800kg and 300hp at the wheels you get 10.2 @131mph with 200 at the wheels you get 11.5 @ 114 IF it all goes to plan good luck dazza
Posted on: 2008/4/18 16:00
Quite a regular
From perth
my ca ute has 313hp at wheels best i have run is 11.37 @ 120mph on 26x6x15 slicks hope this gives you a ballpark figure
Posted on: 2008/4/18 16:56
Registered Users Contentmaster Usermaster
Quote: How are you going to keep the ute down to 800kg after adding a 300hp engine, heavier transmission, heavier diff, heavier brakes, etc? Can't be done on a streeter.
Posted on: 2008/4/18 17:24
Quite a regular
there are far too many variables apart from the fact how well you drive it. I think the best way is take it to the track and run it. Oh and jamb the gas up its arse for good measure.
Posted on: 2008/4/18 22:04
From BRISBANE, QLD
i agree with trx18, there are way too many things to consider...track conditions, elevation, weather.... everyone tends to forget the driver too....do you weigh 60kgs or like me, read fat, 90 plus....i reckon if you can get low 11's with 300rwhp then you are doing well and should be happy, add the nitrous and maybe find a high 10.
good luck, btw sounds like i wicked set up..how quick does that big arse turbo spool up?? my to4e/t3 hybrid is slow as...
Posted on: 2008/4/19 1:23
Back after a long absence and looking to build a beast starting with a 1974 1200 sedan
From Melbourne AUS
ive done 13.9 @ 99 with 150rwhp
around 900kg ute with driver
and naturally there is room for improvement
im confident that i personally could drive it to 13.5 with a good run in the right conditions.
so theres something to think about, with double the rwhp, id be expecting 11's with ease.
Posted on: 2008/4/19 1:30
1973 B110 A12
Quite a regular
thanks 4 the help guys much appreciated
Posted on: 2008/4/19 5:31
From perth
well if 800kg is a bit optimistic give me another weight to feed into the thing my rego papers say 711 kg (coupe) so i was guessing 800kg and guys keep in mind the first word in this thread is "theoreticallly" dazza
Posted on: 2008/4/19 10:00
From Canberra
I would say around 1000kg.
Posted on: 2008/4/19 10:18
