« 1 (2)
Re: datsun 1000 disc brakes. bolt ons from nissan van?
So how did this end up?
Posted on: 2008/4/19 0:27
From Freo
I was thinking the same thing...
Posted on: 2008/4/19 1:53
A15 PSI Project Motor
'72 CB750k,
From Darwin NT
well the calipers are rooted so at the moment im hunting around for a pair then will bolt them on yes the ball joint hole is much larger but the previos owner made up sleeves to go in and tapered them so no problems there just after the calipers any one know whatmay bolt up with little work?
Posted on: 2008/4/19 4:34
current project 4x4 patrol...
No not really I was waiting and watching you so it'd be easy for me!!
Nah okay, has anyone tried a vanette C22 disk and caliper setup? I have access to the parts and I'll give them a go when I can.
Posted on: 2008/4/19 4:49
From Darwin NT
well update tryed it on a front end and a bit of work needed and parts
1600 tie rods
vannete upper and lower ball joints
and then you have to modify the 1000 bits to take these parts and you will be getting a bit of neg camber (better for the racers?) any way i will get pics of it up against a 1000 drum and hub assembly
Posted on: 2008/5/3 11:21
From perth airport
yeh defiantly also perthutee did you get my reply about the gaurds?
unshore? i went back to my stock gaurds and sold the firberglass one's ,
anyway how'z the brakes been goin?
Posted on: 2008/11/12 12:31
perth airport parking
Datsun 1200 ute A14
« 1 (2)
