radiator troubles
From BRISBANE, QLD
guys and gals need some info on what people are using for their 1200's with a ca18det convo...
the intercooler i am running fills most of the front grill section so i guess the stock ca radiator is not getting full flow and as space is tight i only have one thermo, which comes on at 72 degs. the car overheats really quick. travelling at 100 kph it will still over heat in about twenty minutes..something is wrong
now granted i am running a much larger turbo and it is trying to make more power, i had a silvia years ago with big turbo on a ca and the intercooler cover 90% of the front of the radiator yet it never overheated once in 20000 kays and i flogged that thing.
i am removing the radiator and checking if it is blocked but i think i should just go a bigger core or something....this is where you guys help...thoughts
thanks from an overheated rupert
Posted on: 2008/4/21 5:09
Back after a long absence and looking to build a beast starting with a 1974 1200 sedan
Re: radiator troubles
From Sydney
Do you still run the windage tray under the car. It does infuence the temp.
Posted on: 2008/4/21 5:46
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From BRISBANE, QLD
um no i don't, this why i ask you guys...should i run it?
Posted on: 2008/4/21 5:47
From Brisvegas, oz
check your thermostat and make sure you dont have a dodgy head gasket?
Posted on: 2008/4/21 8:26
www.camerasplus.com.au
From Christchurch NZ
The sump deflector thing creates an area of low pressure behind the radiator which facilitates greater air flow through the radiator.
Posted on: 2008/4/21 8:49
Forced Induction!
From BRISBANE, QLD
good but it think i am still ot probs with my radiator...anyone using aftermarket jobbies?
what works well? i am planning a 320rwhp car so need good cooling, i think the windage tray may not fix it totally
Posted on: 2008/4/22 2:45
