stanza struts/vented discs
From Melbourne AUS
does anyone know of a vented disc and brake caliper combination that are a bolt on upgrade for stanza struts?.. im sure the stanza discs would slow the 1200 ok but wouldnt mind vented discs to avoid brake fade on repeated hard braking
Posted on: 2003/6/1 13:03
1973 B110 A12
Re: stanza struts/vented discs
From Melbourne, Australia
i got vented pintara with hi-lux 4 spots
need small mods to disc but is pretty cheap to have done
Posted on: 2003/6/1 13:07
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Melbourne AUS
whats the brake perfomance like?
what mods where required? and what size are the pintara dics?
still wanting to get rid of that coupe dash u told me about?
Posted on: 2003/6/1 13:11
1973 B110 A12
stops very very well, oh it also has sunny booster and 180b master and bluey discs on back
disc is around 10.5" i think, basically the centre hole on the disc needs to be opened up a little to fit the stanza strut
you also have to grind a tiny bit of the caliper down so it doesn't hit the hub in the centre (can do this yourself)
havent been to my 2dr sedan for ages so i still havent looked at it, i will do that this week, have to get some pics of car and will do dash at same time
Posted on: 2003/6/1 13:22
1200 Coupe Rallycar
From Melbourne AUS
thanks.... you havent by chance got some straight chrome trims for the front guards and some good scuff plates with your sedan have u?
Posted on: 2003/6/1 13:32
1973 B110 A12
im not parting out the sedan, what are scuff plates anyway???
Posted on: 2003/6/1 13:54
1200 Coupe Rallycar
theres a couple of sedans around the wreckers here, pick-pay-and-go and kilsyth auto dismantelers, from memory the one at pick-pay-and-go (ringwood) has nice good condition chrome bits on it but that was a few weeks ago now
Posted on: 2003/6/1 13:56
1200 Coupe Rallycar
From Melbourne AUS
theyre the trims that go in the bottom of your door jam over the carpet..... i think theyre called scuff plates anyway
Posted on: 2003/6/1 14:06
1973 B110 A12
From Newscastle, Australia
Hi Rallycar exactly what mods do you do to get the Pintara/Hilux combo on the strut. Also what lower control arm would you use?
Posted on: 2003/6/2 0:58
From sutho shire
hay i got standard 1200 struts in front and getting r31 dba rotors is it a easy adapt on the strut?? i havnt had a look yet?? reason i got them is 2 match rear r31 diff! ne one help me?
Posted on: 2003/6/2 8:57
