Scorpion diff
Not too shy to talk
From Brisbane
According to the Datsun1200 Modification page, you can fit a Scorpion diff into a Datto1200... Does anyone know which model Scorpion this is, because AFAIK different model Scorpions had slightly different diffs (and the diff centers aren't always interchangeable). Also, does anyone know if there is a diff ratio available that's closer to 4.11? Are there any LSD options?
Thanks
Posted on: 2003/6/3 2:57
The FookStar
Re: Scorpion diff
From Sydney, Australia
Scorpion LSD is rare and expensive. That's what I heard, in regards to the scorpion diff.
My dad uses one in his AE86 sprinter (non-LSD). His has a 3.4 ratio or something like that. It works fine with the installed SR20DET.
Chris.
Posted on: 2003/6/3 4:49
Re: Scorpion diff
Not too shy to talk
From Brisbane
Apparently I can get an LSD center from the 4x4 L300 van (diff ratio about 4.6 or something), but then I suppose there is the issue of actually finding one...
Posted on: 2003/6/3 5:56
The FookStar
Re: Scorpion diff
From Melbourne AUS
speak to CA18det_man
he used one behind his ca with the l300 van centre u mentioned.....
i know that he had to use fwd offset wheels to fit....
im sure he'll be happy to tell you more
Posted on: 2003/6/3 8:31
1973 B110 A12
Re: Scorpion diff
Not too shy to talk
From Brisbane
Thanks for that
Have already emailed him, but am still waiting for a reply... (he was the one who wrote the article that I read about using the scorpion diff...)
Posted on: 2003/6/3 10:07
The FookStar
Re: Scorpion diff
From Mudgee NSW Australia
Hi there Im sorry for not answering your email I get quite a few to reply to each day a few weeks ago i lost my entire email box the famous shift and delete I accidently deleted the lot including quite a few unread emails. Good luck finding a LSD I searched for quite a few years while i was running a scorpian diff in my coupe. I could only find either a 4.6:1 4.8:1 and a 3.3:1 expect to pay heaps if you do find one most LSD hard to find are $800+ a 4.11 would be sweet Ive been told the later Mitsi Triton utes have the same center they look the same but havnt had one out to check maybe LSD is an option with them??
Andrew
Posted on: 2003/6/3 12:45
Re: Scorpion diff
Not too shy to talk
From Brisbane
$800? Wow... that's a fair bit. Ah well, will try to check out the Tritons if I get a chance...
Thanks!
Posted on: 2003/6/3 13:45
The FookStar
