front end troubles
Quite a regular
From Hartswater South Afrika
Hi there
I have 1200 gx that i use for gymkhana but i need to get my front suspention harder , can i use any other datsun coils spings and stabiliser bar as there is to much body roll and the front end is too high
help please
Posted on: 2008/5/28 19:57
Re: front end troubles
From Las Vegas USA
Curious as to what class you run: When we first started running the 72 Coupe, I ran in stock class and the car was very competitive at local autocross (our Version of Gymkhana). Never found the car to have a lot of roll.
240Z springs will fit on the 1200 strut perches but will likely raise the nose unless you cut a coil out (legal in South africa?) I seem to recall the 120Y front bar can be made to fit.
If your in a mod class then lowering the car should be easy enough and getting a set of sway bars would be the way to go. sizes we use are 7/8 front and 5/8 rear which I think is around 21mm and 15mm roughly.
Tom
Posted on: 2008/5/30 4:11
the easy way out is put a motor in it
Posted on: 2008/5/30 8:59
Quite a regular
We have very small rear wheel drive classes,1 for under 2000cc and 1for over 2000cc,front wheel drives are huge thouth
I have a alfa romeo limted slip diff in the back that made the back end come down a bit now it stands with the front end higher than the back,that can be the cause
I can cut springs as my car is not road legal
click on my web link ,maybe that can give an idea
Posted on: 2008/5/30 19:03
Quite a regular
will 120y d coil springs be harder than std 1200 gx ones
Posted on: 2008/6/2 20:15
1200 GX uses the same springs as regular 1200: 89.6 lb/in
B210 (120Y) springs are slightly heavier, but not by much. They are longer though. B310 front springs are 90.7 lb/in for A12 engine.
Most racers look for somewhere around 175 to 225 pounds is what I've heard.
Posted on: 2008/6/2 22:27
From perth
you may want more damping
not just more spring
dazza
Posted on: 2008/6/3 12:15
