« 1 2 (3)
Re: Daveman's swaybar madness (pics)
From Sydney
Here is a very handy chart on sway bar sizing and percentage difference. [chart sourced from whiteline suspension]
from the chart, going from a 18mm to 25mm sway bar is a increase in stiffness of 272%
cheers
Benny
Posted on: 2008/6/18 6:45
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Adelaide, Australia
My dad is a big believer of stiffening the car and using softer springs and valving, he doesn't like the way I have set my car up at all. I say go for it, doesn't hurt to try these things, but (you have konis don't you?) I'd set the valving softer and maybe look at trying some 200lb springs.
What are your alignment settings?
Posted on: 2008/6/18 8:50
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Brisbane, Australia
this is different to what I'd been going by. an old suspension book said to compare rates of different sway bars you use the cube of their diameters. But this chart gives different results than that does. Whiteline chart added to my modification bible - thanks Benny. That actually changes what I though I needed for a front swaybar though....
Posted on: 2008/6/19 5:14
« 1 2 (3)
