suspension
Quite a regular
From melbourne
my suspension has seen better days and when i go over 80ks the car starts to touch the wheels...am i best off just going to pedders and letting them have a look at it or does anyone else have any better ideas? any ideas on cost?
Posted on: 2008/6/23 9:36
Re: suspension
From Melbourne, Australia
what car do you have?
front or back or both?
Posted on: 2008/6/23 9:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: suspension
Quite a regular
From melbourne
1200 ute of course and its the front
Posted on: 2008/6/23 9:42
Re: suspension
front... probably best to get pedders to put some shock absorber inserts in for you (around 300-$400 at a guess)
you may want to get disk brake struts first if you have drums though
Posted on: 2008/6/23 9:47
1200 Coupe Rallycar
Re: suspension
Quite a regular
From melbourne
na i got discs..cheeers
Posted on: 2008/6/23 9:58
Re: suspension
From Melbourne, Oz
I found pedders to be fairly expensive, and they never greased my new rod ends, and the thee bolts on top the strut tower wernt tightend, and just lazzy stuff like that. I would sujest just going to your local mechanic.
Posted on: 2008/6/23 10:06
"I hav achieved wood"
Re: suspension
From Adelaide
its easy enough to change them urself,
i changed mine, just go to ur local supercheap, sprint auto parts or burson's and order some in,
all ya have to do is take ya spring off then undo the nut that connets to the strut, pull the shocker out, becare because there should be oil in the bottle, but only like 30ml.
replace with new oil, insert shock then do the new bolt up and reinstall ya gear
Posted on: 2008/6/23 10:23
Re: suspension
damn you do make it sound easy.........
but of course it is no where near that easy
Posted on: 2008/6/23 13:05
1200 Coupe Rallycar
Re: suspension
From Tamworth , NSW
also add to that list,
removing wheel
compress springs,
remove nuts holding strut top on
unbolt the balljoint of the bottom,
remove brake lines
remove strut
then do what crazy1200 says.
then do it all in reverse.
then do the other side.
then bleed the brakes.
yeah easy, youll be done by play lunch.
Posted on: 2008/6/23 13:18
Re: suspension
bwahhahhhhahahahhhahahahhhaaaaaaaaaaa !!! if only it was that easy !!!
