CA18DET 5 speed V's Sumpy 5 Speed...
From Melbourne ( West )
I have a Datsun 1200 Ute.
Can someone plz tell me exactly how much longer the CA box is compared to the Stumpy?
Does anyone have any pics of shifter positions (especially in a ute) Of either box?.
A few people have told me the CA box is a better box - smoother, stronger. but, too long for the ute.
Any help would be great...
Cheers
Posted on: 2008/7/17 13:07
'78 Ute CA18det Project
No matter where you go... There you are
Re: CA18DET 5 speed V's Sumpy 5 Speed...
From perth airport
stumpy comes through the stock hole ca is 10 or 15 cm back
ca box is better
pick of where it pops out in my albums
i like where is pops out :)
Posted on: 2008/7/17 13:37
perth airport parking
Datsun 1200 ute A14
From Brisvegas, oz
ca sit about 60mm behind where the stock sits
Posted on: 2008/7/17 23:44
www.camerasplus.com.au
From Sydney, Australia
the shifter will come up 50mm in front of the double thickness panel that the handbrake connects to.
Posted on: 2008/7/17 23:55
From Arlington, TX, USA
How did you sort out the handbrake? Mount it further back?
Posted on: 2008/7/18 3:30
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From Brisbane
shortened the handbrake lever, on my coupe
Posted on: 2008/7/18 4:59
in my sedan I moved the handbrake 5 inches backwards.
It meant drilling out spot welds for the mounting plates.
Posted on: 2008/7/18 5:18
From Sunnybank, Brisbane
definately use the ca box mate. drop ure handbrake to the side of the tunnel close to the drivers seat (standard lever)
and once u got the box in remove the gear stick and turn it 180 degrees. puts the stick right where u want it. if u leave it on the standard backwards lean its a little too far back (for my liking anyways)
all the best mate
Posted on: 2008/7/18 5:34
Thanks guys,
Seems CA is the way to go?!?!
What about tunnel size?
Was going to use a 180B tunnel with the stumpy box.
Probably going to use CA box now - A few good reports... Thankyou!
I am assuming I will still need the bigger tunnel? - What have you guy's done?
sooty_grunter - Have you got any interior pic's mate?
Posted on: 2008/7/18 6:29
From perth airport
some say u can use the stock tunnel
i went maddat
but im gonna see how a tunnel out of a silvia looks coz if you buy a half cut why not use all of it :)
Posted on: 2008/7/18 6:59
Datsun 1200 ute A14
