diff info
From tasmania
Not knowing how to tell one daddo diff from another .how do you tell a 145-150-165. I have the back end out of a 12y 4 door I wrecked I was wondering what diff would be in it .
Posted on: 2008/8/5 10:39
Re: diff info
From gold coast QLD.
H150 if its genuine
Posted on: 2008/8/5 10:58
Re: diff info
From Adelaide, Australia
If the centre comes out from the rear and it has a backing plate its a b/w. If it comes out forwards and it has studs its a H145, if it has bolts its a H150.
Posted on: 2008/8/5 11:01
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: diff info
From tasmania
so if it is an h150 would that be strong enough to run behind the L 18
Posted on: 2008/8/5 11:21
Re: diff info
How long is a piece of string? It should handle all right until you do burnouts or hard launches. I have a BW68 behind my L series and it does allright. I haven't blown one in 3 years.
Posted on: 2008/8/5 11:25
Re: diff info
As long as your kind to it could last a while, just don't get a heavy duty clutch and do burnouts.
Posted on: 2008/8/5 11:27
IPRA Build
Re: diff info
From tasmania
so the complete 120 y back end should bolt up to the 1200 so if it chucks a wobbly Il just need to change the diff centre
Posted on: 2008/8/5 11:33
Re: diff info
If you have a H145 in the sedan use the H150 centre with a 2mm shim to align axles.
Have you worked out your tailshaft yet?
Posted on: 2008/8/5 11:36
IPRA Build
Re: diff info
From tasmania
No sean thats why I want to set the back end up so I can do my home work on the tail shaft what yoke I will be running
Posted on: 2008/8/5 11:54
Re: diff info
From Geelong, Vic
revhead, a BW68 is a fair whack stronger than a h150...they have bigger axles than a h165
if you just granny it around like sean then it should last fine
Posted on: 2008/8/5 12:57
