Coup heater into sedan?
From Melbourne, Oz
I hav a coup heater box to go into my sedan as well as a coup center console.
I notived the pipes up to the demister are different.
Are the linkages the same?
Will it otherwise just "bolt in"??
Thank's, Connor.
Posted on: 2008/8/12 12:15
"I hav achieved wood"
Re: Coup heater into sedan?
From Armidale N.S.W
Hey Commor. Not sure about that But i do have a sedan heater box for sale if its to much hassle to fit that one. Works beautiful kept me warm when i left the Motel at Cootamundra at 4in the morning bringing the car home. Make an offer.
Posted on: 2008/8/12 12:24
73 1200 wagon SOLD
From Melbourne, Oz
Thank's andy, but your is porobly the same as my new one I got of powloo and if its not then its the same as the one its replaceing, But thank's anyway!!
Posted on: 2008/8/12 12:28
From Geelong, Vic
only difference ive seen between the early and late heaters is that the early ones have the demister ducting sit in the heater and come out vertically
whereas the late ones slip over a pipe thats sticking out of the side of the heater horizontally
might just need the ducting to suit the heater you have
Posted on: 2008/8/12 12:44
From Armidale N.S.W
Oh o.k. The sedan one i have has the ducts coming out the side. Good luck Connor. sounds like a simple work around find the matching Ducts as PIGDOG said.
Posted on: 2008/8/12 12:50
73 1200 wagon SOLD
From Melbourne, Oz
The duckting thats there allready look's to be well scrunched up, so if I'm luck may be able to use the same pipes!
Thank's Fellas!
Posted on: 2008/8/13 2:41
From Geelong, Vic
yeah the early ducting is that paper and foil stuff, whereas the later ones are plastic
Posted on: 2008/8/13 2:49
From Melbourne, Oz
It must hav bin replace then at some point because its that slinky rap'd in plastic stuff!
Posted on: 2008/8/13 2:52
From Geelong, Vic
might be the old stuff, but i could swear mine was more paper looking....bit both of my ducts got ripped in half so no heater for me
Posted on: 2008/8/13 3:02
I always though B110 ducts were the cloth type, whereas B210 were the plastic. They are same diameter so they interchange.
Posted on: 2008/8/13 3:13
