sedan springs
Quite a regular
From Noble Park VIC Australia
are sedan springs the same as ute springs
Posted on: 2008/8/21 11:06
Re: sedan springs
No, ute springs are heavier duty.
Posted on: 2008/8/21 17:12
Re: sedan springs
Each different car had its own springstack & each, with the possible exception of 2 door & 4 door sedans, was different
Posted on: 2008/8/22 1:51
Love your Datsun.
Treat it well.
Re: sedan springs
Coupe & 2-dr sedan use the same leaf spring assembly (at least in North America): Part Number 55020-H1000
Posted on: 2008/8/22 3:11
Re: sedan springs
From Geelong, Vic
they all have the same length main spring from eye to eye so are interchangable. you will need longer U bolts if running the ute leaves with the load leaf still in the pack though as it adds an extra half inch to the thickness of the spring pack
Posted on: 2008/8/22 9:27
Re: sedan springs
From Adelaide
Does any one have any ute springs for sale?
Pref SA
Posted on: 2008/8/22 9:48
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
Re: sedan springs
From South Africa, Bloemfontein
Can't one then put ute springs in the back of a sedan that is used for track days,etc?
Posted on: 2008/8/22 9:59
1977 Datsun 1200GX
