choke knob
From northern 'burbs adelaide
im having trouble pulling the choke knob off ... the other knobs came off with the push and twist method but this one wont move at all and has no screw in it to undo ... any ideas?
Posted on: 2008/8/24 10:07
Re: choke knob
From Canberra
I dont think its meant to come off... take the whole cable out.
Posted on: 2008/8/24 10:08
Re: choke knob
From Armidale N.S.W
Doesnt the whole cable come out of the sleeve with the knob attached permanently. Then you just put a dob of grease on it when threading it back through
Posted on: 2008/8/24 10:11
73 1200 wagon SOLD
Re: choke knob
well its got a shoulder onthe cable on the other side so i cant pull it out of the dash and i need to get the knob off to feed it back into the dash
Posted on: 2008/8/24 10:12
Re: choke knob
From Armidale N.S.W
A shoulder, You mean at the carby ? disconnect the choke cable completely at the carby pull it back like your pulling it on but keep going till the cable is right out. Then undo the little round nut on the front with the grooves in it then pull it out from under the dash. Carefully bring it out from under the dash and pull it gently through the firewall grommet. Then Wallah ya done.
Posted on: 2008/8/24 10:14
73 1200 wagon SOLD
Re: choke knob
From Sydney
Yes the knob does come off. push and twist...its the same as the others [lights and wipers]
Posted on: 2008/8/24 12:03
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: choke knob
From Armidale N.S.W
Mine doesnt come off unless i break it off. Could be an after market job i guess.
Posted on: 2008/8/24 12:06
73 1200 wagon SOLD
Re: choke knob
choke cable
The yellow arrows point to the washer that needs to be unscrewed before the cable can be removed from the dash.
Posted on: 2008/8/24 19:45
Re: choke knob
From Canberra
ok from that pic the knob must come off. Looks like I've only ever had aftermarket choke cables haha
Posted on: 2008/8/24 23:12
