Browsing this Thread:   3 Anonymous Users
Dyno Hire/Tuning how much are you paying?
From Ballarat Victoria
How much does your dyno time cost you?
A bit of a loaded question as i`m contemplating buying a Dynapack dyno and was wondering if maybe i could recover some of the running costs but mainly it would be used for personal use.
Are you charged per hour, half day, is it only tune time or setup time aswell?
Posted on: 2008/9/4 2:36
VIC DYNO HIRE
Re: Dyno Hire/Tuning how much are you paying?
From perth airport
for a sr20det dyno tune is normaly 500 to a 1000
its charged per hour
how much is a dyno worth ?
most people are very picky who tunes there car so not shore how much work u will get
Posted on: 2008/9/4 2:58
perth airport parking
Datsun 1200 ute A14
I totaly agree, people should be very carefull about choosing a tuner and there is not too many people i`d trust to tune my cars thats one of the reasons for wanting to buy my own.
You would want someone with extensive knowledge in your partictular ecu brand/carb type and engine config. And have large database of customers dyno files to prove it.
As you say, all this does make it hard to build a client base.
The dynos are about $75,000 if thats what you were asking. but i want to buy some In Cylinder Presure Transducers and software which adds about $10,000. These are for measuring in cyl presures when under load and shown on a graph showing pressure
during each degree off engine rotation. This allows for very accurate timing and fueling adjustments and shows up unstable combustion well before detonation starts.
It also plots exact BMEP/HP of each cyl tested.
Posted on: 2008/9/4 4:11
VIC DYNO HIRE
From Melbourne,Australia
Last time i had my car tuned it cost me 100 bucks an hour if that helps would be awsome to have you own dyno but I tuned my car myself fist time around took me 7 hours to get it right! Luckly i used a mate's dyno and it only cost me a slab
Posted on: 2008/9/4 5:47
From Adelaide, SA
i had a basic dyno tune for $170, i only have stock computer so there only so much they could do. $100 an hour sounds about right, thats what i have heard from a few different places in adelaide.
Posted on: 2008/9/4 10:25
From SE Melbourne
I had the same thought a few years ago sikyne and through my research and going and getting demos from Dynapak and the competitors (Dyno Dynamics) I was totally sold on the Dynapack too....just the then $50K price tag stopped me from purchasing.
A dyno run that I thought would take about 15min it would be fair to charge $50 I thought (maybe that should be more now).
Would $100 an hour be reasonable....hmm maybe (just trying to gauge my own tight-arse-meter).
I calculated that it would probably take 5 years to pay it back - 3 if I went hardcore.....but at the time i decided not to give up my day job.
Posted on: 2008/9/4 11:13
Mildman, Datsunless
From perth
it takes the factory guys a year of tweaking to get a new model fully mapped.
they go to saudi ,alaska our outback,canada to test for extremes of weather
you only get 20 seconds to fiddle with the cold start settings then you have to wait until engine is stone cold again
thats the good thing about DIY you get to fine tune
the place i work for used to fly a guy out from the US to tune our fuel funny car at $10k a meeting but its cheaper than a $70k engine blowup
dazza
Posted on: 2008/9/4 13:01
Absolutely, takes a huge amount of time to get tune right. Not too long maybe for a basic fuel and ign map thats way safe. But to tune for best mean/lean torque and optimal ign. as well as getting all the compensation maps right (cold start, batt voltage, accel enrich, baro etc). Days or weeks probably.
Im waiting for a couple of things to unfold before i can buy up. Might be well into 09.
Its interesting to hear what people are being charged. I wouldn`t have the same overheads and would think $65./ hour max.
Edit: MIldman, I priced a dynapack a couple of years ago and was told $50,000 USD (they sell the unit in USD)at the time was $78,000 oz. Called again when the oz $ was .95US and they had put the price up to suit. Not happy!
Anyway it was the best dyno for sensitivity/ repeatability i could find, although i think the dynalog software (designed by Andrew Elder) a lot better. A friend has this on his engine dyno and has exelent logging capabilities.
Posted on: 2008/9/5 1:19
VIC DYNO HIRE
From SE Melbourne
Yeah I found the only weakness with most of these units was the limitation of the software.
I think you could dump the raw data down and line it up with the logging in your engine computer as well (that was what I was going to do).
At the time - I was heaving into engine management tuning I ended up doing a 'freeway' tune. Up and down a freeway with a trade plate....not really quite as effective as a dyno - as runs were in 2nd or 3rd gear. But in the end cheaper for me than buying a dyno.
I agree with the accuracy of the Dynapack - the claim is you can see the dip in torque when the headlights come on! And much more repeatable when you don't have to worry about strapping the car down or the tyre pressures.
When I got my $50K quote was in 2003, that was for rear wheels only...but there might have been some more extras (like software of something) that weren't included at that point...can't quite remember.
Still cheaper than a dyno dynamics!
Posted on: 2008/9/5 4:35
Mildman, Datsunless
I have had my cars done on Dyno Dynamics and Maineline dyno. The Maineline dyno to me looked more honest and the tuner was able to get it right first time. the other good thing about Maineline is that they are made in Australia and would have a better support network to be able to rely on.
then again some times it can be a great unit but a bad operator
Posted on: 2008/9/5 5:20
Don't You Just Love Owning a Road Registered GOKART
