valve spring installation question
Not too shy to talk
From Loveland, Colorado
Is it possible to install the valve springs upside down? I have a GX head with the double valve springs.
If so, what are the consequences of having them installed improperly?
If it doesn't make a difference then I will have a few more questions! :)
Posted on: 2008/10/8 5:20
Re: valve spring installation question
From Melbourne Vic
i would have thought they can go in either way with no difference... but i have been wrong before
Posted on: 2008/10/8 8:18
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
They can be installed either way.
Posted on: 2008/10/8 9:07
It's usually only tapered springs that are designed to go in one way.
Posted on: 2008/10/8 9:53
Some valve springs have the coils closer together at one end & from memory, these go to the top.
[EDIT. Subject to correction by anybody who actually knows for sure.]
If they are equally spaced then it doesn't matter.Quote:
Posted on: 2008/10/8 9:58
Love your Datsun.
Treat it well.
From Oberon NSW {Bathurst}
Dodgeman is correct Re: valves the close end of the spring to top. So sayeth the Springmaker
Posted on: 2008/10/8 10:06
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
From Lisboa-Portugal
I wonder if Mini double valve springs fit GX head? Anyone knows?
Posted on: 2008/10/8 12:00
From perth
close coils ALWAYS go against cyl head
mini too short same as 1.6 ford
crow 4028 good single for a series
dazza
Posted on: 2008/10/8 12:20
From Perth WA AUS
Yeah, I just installed double valve springs & the tight end goes down!
But, being just a spring, it would not matter anyway. the same spring rate will still apply, I am pretty sure.
Posted on: 2008/10/8 12:35
Datsun 1200 2Dr sedan.
What more double valve spring of other kind can we use in a A series head?
Posted on: 2008/10/8 12:46
