valves
From durban, south africa
hey guys,
what bigger valves can i put into my a-12 head?
many thanks
nicholas
Posted on: 2003/6/30 11:33
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: valves
From Las Vegas USA
The stock A-14 valves will fit , while your at it install the dual valve springs. I believe the A-14 Valves are about 2 MM bigger - I'm sure someone else will confirm the size. I believe you also need to install the valve seat to go with the A-14 vavles. I can't remember if we just cut the seats or used new ones to match.
Tom Grossmann
Posted on: 2003/6/30 18:58
