Re: 60 series 5 into 1000 need help
From Melbourne vic
Like this? my box has the traditional fork
out the top but the hole wasn't cut out
it had a casting mark and has been cut after
clickme
Posted on: 2008/10/15 10:12
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From gold coast QLD.
It's not a big deal,i 'm assuming the 5 speed 60 series box has the same fork arrangement as a normal 1200 box.
You need to set it up and mark the area to be caressed,get the box out and take to it with a big hammer to get clearance.Alternately you can cut a section of the tunnel out and alloy box it over,i've used both systems without too much drama.
We had to do this also when fitting the Celica box.
Posted on: 2008/10/15 10:13
From Darwin NT
nope not hydrualic they use the same style clutch as what is on the 120ys
its not to hard but id take out the motor to do it i just cant be bothered to do that
cone head if you dont mind you can send up that 5 spd of yours to me
Posted on: 2008/10/15 10:15
current project 4x4 patrol...
You don't need to pull the motor out just the box so you can get a decent swing at it,or as i said,leave it all in and cut a square section out from inside with an angle grinder and build a nice alloy box over the top
Posted on: 2008/10/15 10:20
From Melbourne vic
LOL! If you click the link, i think this is what he means by hydraulic. i think this is an L
not an A but
:Nice
From Darwin NT
yeh that looks like an L i think all the A boxs were cable and not hyd
Posted on: 2008/10/15 10:27
From Melbourne vic
Out of interest how did you go with:
(A) reverse light switch fitting
(B) rear crossmember
(C) shifter position in the car
(D) all of the above
Posted on: 2008/10/15 10:31
:Nice
From newcastle, NSW
63A comes hydrolic and cable from memory, its basically an L-series box with an A-series bell housing.
Posted on: 2008/10/15 10:38
From Darwin NT
reverse light dont need with a wagon
rear cross member needs to go forward 2 inches
shifter will be the same
Posted on: 2008/10/15 10:56
From Melbourne vic
I was told that the standard switch position
on a 60a wont fit in the tunnell-confirm
or deny pls ( i have a coupe)
Posted on: 2008/10/15 11:04
:Nice
« 1 (2) 3 »
