WTB: Coupe Driver's Door - CA, USA
From Cambria, California
WTB a USDM '71-'72 coupe driver's door shell. (that's the OTHER side driver's door, rally1200! ) Will swap my LH & RH '73 coupe door shells, maybe throw in a RH glass/regulator/wind wing set to sweeten the deal. (the '73s have a ~15lb side impact beam built in, 30lbs which my race car doesn't need)
Posted on: 2008/10/21 18:27
Re: WTB: Coupe Driver's Door - CA, USA
From Albuquerque NM, USA
I am currently trying to aquire another coupe, and may end up with an extra door.
However, I have been trying to aquire said coupe for about a month( the guy is emotionally attached to the car...aren't we all). The extra door I would end up with is not in the best of condition but I will keep you in mind should I end up with a spare.
Kelmo
Posted on: 2008/10/21 18:35
Thanks for the offer - send pix when you get it.
Stan
Posted on: 2008/10/21 19:46
From Las Vegas USA
Stan I have at least 2 sets of doors possible 3................and of course you were probably up here for the VARA weekend.(my son had a cross country meet so I was a no go) I could have even given one to Larry Hassler to drag back or drop it at Les's shop.
Steve Smith is a local long time VARA member, if both of you will be at Willow Springs on the 8th maybe we can get one to you that way.
Tom
Posted on: 2008/10/22 1:44
Well, I'll be...sign me up for one of those LH doors if they're the earlier versions!
Didn't make LAS, but could make Willow easily; it's just a run up Cajon Pass from here.
It would be a good time to say Hi! and get some 'role model' tips for my restoration.
PM sent.
Posted on: 2008/10/22 5:39
