« 1 2 3 (4)
Re: once again the s13 disk conversion
From Burpengary
ok I'm officially confused. I have drum struts/hubs and the s13 setup. IF I understand correctly, I need not only the adaptor but also a spacer block? Has anyone got a template I can get a hold of?
I tried fitting my s13 rotor onto the drum hub today and no go, the centre hole needs to be bored out by nearly 10mm. Is this what everyone else has found??
Posted on: 2008/10/22 13:57
From Sydney
I recently built up another set of the S13 [CA 250mm rotor] conversion on B110 drum hubs and KB110 struts. In order to get the caliper to rotor allignment correct, I sacraficed the original drum and machined it on a lathe and turned it into a spacer [5.05mm].
I did not have to modify the drum hub at all.
I did not have to modify the rotor either.
Posted on: 2008/10/23 1:13
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From SYDNEY,NSW
how do i contact this "kev rowley"?
cheers
Posted on: 2008/10/23 1:26
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
From Brisvegas, oz
kevs number is (07)38144674
Posted on: 2008/10/23 2:46
www.camerasplus.com.au
From SYDNEY,NSW
thanks for that!!!
god i love this site.
Posted on: 2008/10/23 8:11
From SYDNEY,NSW
i have now got my rotors and calipers, and drum struts ready to get started on this, can anyone point me in the right direction for someone who sells the brackets?
cheers
Posted on: 2009/3/15 10:02
From Christchurch NZ
Does anyone have a drawing (With measurements) of the s13 caliper to disc brake stub axle adapter? It seems that there is a flaw in the deisgn of the ones I've been using.
Posted on: 2009/3/16 7:14
Forced Induction!
« 1 2 3 (4)
