« 1 (2)
Re: Megasquirted L banger
sikyne wrote:
I can do most things....but no sexual favours.
Awwwww Nuts!
Posted on: 2008/11/23 11:26
no he doesnt do them don... but how did i know you wouldnt take no as an answer
Posted on: 2008/11/23 11:59
From Coondle, WA Australia
Whats with the two basss fittings under the back of the plenum chamber? Emmision control perhaps?
and is there a reason that the plenum is tapered towards the back?
Posted on: 2008/11/23 16:03
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Cape Town ZA
I wouldn't know what the two brass fittings are for, but the tapering to the back is to ensure that those cylinders get the same amount of air at the same speed as the forwards cylinders.
Posted on: 2008/11/23 18:12
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Looks a lot like one of those fittings is going to the fuel pressure reg, then I guess the other could be to the brake booster or the map sensor.
Posted on: 2008/11/23 21:05
Quite a regular
Yeah Daveman got it in one.. It is just a couple of outlets for manifold pressure for things like the MAP sensor, fuel regulator, boost guage (one day) and i'm also playing around with a cold idle up valve too..
Posted on: 2008/11/23 23:37
« 1 (2)
