question about breather pipes
From tasmania
Running twin hitachi carbies on the l 18 . What to do with tappet cover breather and the breather on the side of the block .Running sports cleaners on the carbies don't what to run the original air cleaner When I got the motor it had foam straped around them MMM???
Posted on: 2008/11/30 5:15
Re: question about breather pipes
oil catch can breather set up would be the go. There should be a PCV inlet valve on the su manifold
Posted on: 2008/11/30 5:29
The breather system is the opposite of a regular A12. The twin carb system is:
* Rocker cover to PCV valve
* Block breather to air cleaner
Posted on: 2008/11/30 8:04
From Launceston, Tasmania
You can buy small rocker cover breathers from places such as pabs or bursons, all you need to do is measure the breather pipe size.
I run one on each of my A series motors, as I have a weber carby on both my 120y coupe's, which have sports air cleaners.
Cheers.
Posted on: 2008/11/30 8:42
From tasmania
Doesn't the l series motors blow out of the tappet cover it would be blowing into the filter wouldn't it
Posted on: 2008/11/30 8:49
From Geelong, Vic
shouldnt really be blowing out the rocker cover breather as such, there will be a small amount of air pushed out as the engines running
but if excessive amounts of air/smoke are coming out then you have a blow by issue
Posted on: 2008/11/30 9:51
From tasmania
no it runs very clean mate just a wisper of air is blowing out tappet cover
Posted on: 2008/11/30 10:14
From newcastle, NSW
in the past i have put a little K&N filter on the breather on the tappet cover, but apparently thats illegal, the catch can option is the way to go, thats not illegal.
Posted on: 2008/11/30 13:41
it is if it vents to the atmosphere, legally has to go back into the induction system to be burnt up by the combustion cycle once again.
Posted on: 2008/11/30 23:06
