a15 electronic distributor
From New Zealand
an anybody help identify this dizzy i got with an a15 engine?? I'm in NZ if that helps, and have no idea if its out of a vanette, if its an e15 dizzy modified or something else. The
identifying numbers on the outside are:
D4R80-08 2404
22100 11M00
identifying numbers on the inside are E12-61
the base plate/adjustor plate has been modified to fit also (can see this in photo 4). There's no hole for a screw to go through anymore, just a chunk of metal to bolt bown on with a washer. Also the cap screws on, not the usual clips. Thanks
Posted on: 2008/12/7 6:01
Re: a15 electronic distributor
I'm guessing it is the 1989-up JDM distributor, since it has the two cap hold-down screws and the factory nissan reluctor cam. These would come from Sunny Vanette or Sunny Truck. When I get back home from hawaii I'll check mine to verify.
Posted on: 2008/12/7 7:30
From Christchurch NZ
Post a picture looking down on the gear. One of those pictures looks like the housing had been ground like what needs to be done to an E15 unit.
Posted on: 2008/12/7 7:37
Forced Induction!
After checking the parts catalog, I see the pickup plate doesn't match the 1989-up type.
Posted on: 2008/12/7 7:49
From hastings,vic
e15 dizzy
Posted on: 2008/12/7 8:07
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From bathurst nsw
id say an e15 dissy too, ive got one in my race coupe
Posted on: 2008/12/7 8:27
My car gets me from A to B...Just faster ;)
From New Zealand
shows modification needed to plate
view from top
Posted on: 2008/12/7 8:34
I'd say E15 too. (or is that three?)
Posted on: 2008/12/8 5:30
Forced Induction!
From hastings,vic
my e15 dizzy for my a15
Posted on: 2008/12/8 8:02
