1200 Coupe Sill Panels
From Portland, Vic
Does anyone know where I can buy coupe sill panels from? There seems to be plenty of places that sell 1200 ute sills, but not coupe ones. Can the ute ones be used on the coupe? i.e are they long enough and are they the same shape the entire way though?
If anyone could help out, it would be great.
Cheers.
Leigh
Posted on: 2003/7/11 15:06
- 1985 Datsun 1200 Ute - S5 13b Turbo
Re: 1200 Coupe Sill Panels
From Canberra, Australia
From what I can gather coupe sills are no longer available. The ute sills are shorter by about 100mm. I have just replaced RH sill on my coupe. I got 2 ute sills to make one coupe sill. Other than the length, the ute sills are exactly the same.
Neil
Posted on: 2003/7/11 21:04
From NSW South Coast
why are the ute sills shorter when the wheelbase is ihe same. Do the utes have bigger rear wheel arches.
olboy
Posted on: 2003/7/11 23:02
From Portland, Vic
Any tips on replacing them? I am going to do it myself, but would like to have a bit of a clue before I start. I gather thes best way is to drill out the spot welds first and go from there?
Cheers.
Leigh
Posted on: 2003/7/12 0:46
From Warwick, QLD
hey Leigh,
Contact
Craig Vayne
Sheetmetal Fabrication
(07)41223921
He's based in martborough I think in QLD the sil costs $35 and it fits coupe or ute pretty much any 1200. It's a long piece that has been fabicated to the right shape, it's long enough to do both sides just cut ti to the right length.
To get out your old sill just grind out where you want to join it up at and use a chisel to undo the spot welds on the seam underneath and take off the door edgeing to get to the top seam and chisel that then just weld in ya new piece and put it all back together.
PS rear 1/4 panels are availible from this guy for $25, it goes from the wheel arch back to the rear of the car and comes up 20cm.
Part numbers are
Sill Outers $35 code: RP168
Rear 1/4 $25 code: RP167
Hope this helps
Cheers
Damo
Posted on: 2003/7/12 3:16
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Mudgee NSW Australia
I must have been lucky I replaced both my sills with genuine nissan ones they didnt cost that much either from memory around $80 a side mind you that was like 4-5 years ago same with the front guards they cost $130 for LH and $140 for RH I dont know if they still got any to sell genuine.
Andrew
Posted on: 2003/7/12 9:20
Olboy
The coupe has wider doors. The coupe sill is longer from A pillar to B pillar.
Neil
Posted on: 2003/7/12 23:19
From California
Mistakenly thought you were referring to scuff panels, not sill panels.
Posted on: 2003/7/12 23:25
From Portland, Vic
Thanks for the replies guys.....and thanks Damo, I shall give that guy a yell I reckon. Pretty cheap and I'm doing them myself so we'll see what happens.
Thanks again.
Leigh
Posted on: 2003/7/14 1:56
