speedo out?...why so much?
From Brisbane
my a14 is in with, 5speed (60a) and h165 diff, but my speedo is out alot at 92km i am actually doing 80km...... what do i do to rectify this and why is it out so much ? cheers
Posted on: 2003/7/13 9:13
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: speedo out?...why so much?
From Warwick, QLD
goto the transmission shop and tell them how much it's out and give them the cog off the end of your speedo drive cable.
They will give you one to rectify it, if it ain't right then you can always get another one. Mine cost $5 for a new cog.
Cheers
Damo
Posted on: 2003/7/13 9:46
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Canberra, Australia
you also forgot your new wheels...
Posted on: 2003/7/13 13:08
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From T'ville
are the diff gears 4.11 ute gears or 3.8,3.9 B'bird gears also what whl/tyre set is on the car.
cheers
Posted on: 2003/7/14 13:14
From Brisbane
umm 4.11, 14/185/60r, wasnt much difference with the old a12, but since upgrade to a14 and 5speed 60a, the speedo has gone out heaps
Posted on: 2003/7/14 13:20
From T'ville
my guess is speedo drive gear is wrong for the 4.11 diff like the other guy said you may need another drive gear
Posted on: 2003/7/14 13:42
Are you sure you didn't hit the end of the speedo so hard that you bent the needle???
Posted on: 2003/7/14 13:49
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
From Castro Valley,CA USA
My guess is the transmission.
Same thing happened to me. I found that the output shaft on the 5spd has something like 6 teeth and the 4spd has 7. These are the teeth that are machined as part of the output shaft (= can't replace).
Posted on: 2003/7/15 0:59
From Millgrove Vic OZ
Take the speedo drive gear out of your old box and see if it fits into the new box.
Posted on: 2003/7/15 2:16
Cheers Feral
