I am such a D1ck!!
From Oberon NSW {Bathurst}
I have been having trouble with my headlights. Put it down to the switch at my first inspection so our good friend DatsAndy shoots me a switch. It checks out, so out with the old in with the new, STILL NO LIGHTS Check old switch it is ok So, out with the dash and into the wireing we go. The last of the great white electrical hunters stalking its elusive pray. Hours into the hunt we have power but only intermitently, WTF Now I checked the fuses but not the fuse box. A bad fuse! Not Blown but broken under the nickle cap Looked OK tested OK but it would make then not make a contact and a loose mains conection. I am such a D1CK 5 minute job turned into 5 hours. I am looking for some understanding and compassion here because I told my friend and his reply was, you guessed it! YOU ARE SUCH A D1CK!!!
Posted on: 2008/12/18 13:08
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
Re: I am such a D1ck!!
From Freo
it's ok, your not the first..
Posted on: 2008/12/18 13:10
A15 PSI Project Motor
'72 CB750k,
That's happened to me, it is the nature of electrical work I think.
Posted on: 2008/12/18 17:46
Quite a regular
From Inner West Sydney
Been there done that !
On my son's 1200 ute drove home from TAFE with no lights, did the pull apart then same thing fuse wot looks ok but was a dud. My son is an apprentice sparky and guess who figured it in the end.
Posted on: 2008/12/18 21:10
From gold coast QLD.
I too will fess up to this.
The message here is regularily pull all the old glass fuses,throw them over your shoulder and replace with new ones
Posted on: 2008/12/18 21:21
From Schofields
i agree with bert but the other thing would be....
when the electricals fail or not work properly check the fuses b4 the big pull apart!!!
Posted on: 2008/12/18 21:32
Thanks I feel much better now I am going out and put my seat back in now.I left that bit out, I had to take the seat out so I could get under the dash I gotta get my butt down to weight wachers or something
Posted on: 2008/12/18 21:40
Cheers Peter.
0427 138 266
From Armidale N.S.W
HA HA Gotta love the electrical Mind games. Once i replaced the main plug with ignition wires in it cause the old one was perished. Put all dash back in and everything she would start but i had to hold the key on and when i let it go it would die tried heaps of stuff the ignition the starter motor. Could it be the plug (Denial creeps In at this point)? finally said to self Self check the plug pulled the plug off well the plastic part that contains all the individual wires then just connected them all up and bang started and ran. Now the wires are individually heat shrinked and bound with electrical tape. Was the new plastic housing $9 to throw it over the shoulder and me pup chewed it up. Made a good dogs toy i guess. Moral to the story, Your not alone Pete.
Posted on: 2008/12/18 23:03
73 1200 wagon SOLD
From Coondle, WA Australia
Thats why they call it elecTRICKery....
I feel the pain.....
My first pootrol had intermitant faults everywhere. i would contantly blow fuses, and generally be a pain in the arse.
took it to a sparky who said that it was a dodgy fuse holder.
Replaced that, still no joy.
My brother and I found out what happened in the end.
I had split a battery apart out driving one day, and the acid had leaked over the main harness and back into a big connector. The battery acid slowly ate the wires and corroded the connector. It all looked fine on the outside, but internally it was shot. It would even test fine with a multimeter when ever we checked.
Once we found that out, and realised it needed a rewire, it was promptly sold to a dealership for $3000. (gotta love the minimum trade in deal)
Electrickery is just one of those painful things that old cars come with.
when you look at most of the posts on this site of people at their wits end over something, its almost always about intermitant electrical faults.
I share you pain...
Posted on: 2008/12/19 11:04
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From South-Africa,Pretoria
Okay i have struggling the last week with dash lights not working, stripped the whole dash found no indication of blown lights, nothing. Tested the fuse's they all fine... now u tell me they can be dud's ? :(
Posted on: 2008/12/19 11:51
1993 Nissan Bakkie - Rebuilding A15
www.spitronics.co.za
Keep it OldSchool, keep it Datsun
Some can afford the legends, other try to revive them.
