looking for a15 dizzy
From pooraka,,adelaide
im looking for an a15 dizzy im located in adelaide sa msg or call would b the easiest way to contact me 0450342108 thanx guy's
Posted on: 2009/1/3 15:55
Re: looking for a15 dizzy
From hastings,vic
modify e15 dizzy, thay work well
Posted on: 2009/1/4 0:15
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
wot would i find an e15 dizzy in..?
Posted on: 2009/1/4 1:33
From The garage, NZ
an E15.....
Posted on: 2009/1/4 1:48
Just use an A14 distributor. A12 distributor will also fit.
Posted on: 2009/1/4 5:46
yer i have an a12 one in there but i have a weak spark so i wanted to improve that with a bigger dizzy
Posted on: 2009/1/5 20:59
From Freo
Weekend 1000 has Electronic Dissy's for A series..
pm him..
Posted on: 2009/1/6 0:03
A15 PSI Project Motor
'72 CB750k,
A15 dizzy is not bigger, nor has a bigger spark. A12 dizzy is just as powerful...
Are you saying you want an electronic ignition distributor that will fit an A15? That is do-able.
Posted on: 2009/1/6 3:07
From Oberon NSW {Bathurst}
Just put a new condenser, points. You could try a 7 volt coil ex bosch/early ford/vw. With no resistor that will give some hot spark but is murder on the points
Posted on: 2009/1/12 13:14
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
