Difference between 120y diff to a 1200 diff ???
Quite a regular
From melbourne
does anyone know whats the Difference between 120y diff to a 1200 diff ??? i herd the 120y diff is better but why?
Posted on: 2009/1/5 22:32
Re: Difference between 120y diff to a 1200 diff ???
From perth airport
1200 ute diff is the best its the strongest out of the lot
1200= h150 diff
120y = h150 diff
1200 ute =h165 diff
Posted on: 2009/1/5 23:22
perth airport parking
Datsun 1200 ute A14
From sydney
1200 has a 145mm crown wheel and a 120y has either a 150mm crown wheel or a borg warner, which is stronger again.
Posted on: 2009/1/5 23:49
* B210 was fitted with at least three different types of diffs.
* B110 and early utes was fitted with at least two types, and in aluminum or cast iron.
* Newer utes have the H165
The best one is the B110 wagon diff: it is the lightest, with aluminum carrier, bolts directly into most sedan/coupe/early ute.
Posted on: 2009/1/6 2:58
Quite a regular
From melbourne
kool thanks for the info... big help
Posted on: 2009/1/6 5:55
From Adelaide S.A
The aussie 120y borgwarner 68series diff would be my pick, plenty strong for most combos and parts are plentiful unlike ute h165 diffs. Its also a bonus that they practically bolt right in. Dont forget the tailshft will need changing/modding as the diff flange is different. If you end up breaking these the next upgade would be borgwarner 78series modded to suit from r31 skyline and the likes with lsd an option
Posted on: 2009/1/11 12:30
Affordable Performance and Mechanical Repairs
0421 221 821
Adelaide
