diif conv on 1200 ute!
From sutho shire
hay getting set up for turbo motor i want something that will hold up 2 (300hp )
anyone can post info thanks heaps! defenetly a locker diff!! hehe i like going sideways!who doesnt
Posted on: 2003/5/28 14:47
Re: diif conv on 1200 ute!
Check out the What diff? article in the tech section.
Posted on: 2003/5/29 5:24
From Gold Coast (Auz)
i own a ca18det 1200 ute it has a shortened nissan shillouete lsd diff in it
Posted on: 2003/7/17 13:50
From Canberra, Australia
don't go a locker.
If you have spent the money on doing the turbo conversion then go that little extra effort for an LSD...
Posted on: 2003/7/17 13:56
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From T'ville
series 3 b'bird . yet to see one break
Posted on: 2003/7/18 18:34
Quite a regular
From Sunshine Coast
I have a 1200 ute with a CA18DET and i have used a mazda B1600a diff housing with bravo LSD centre. All i had to do was move the mounting points on the housing change the stud pattern and get new bottom plates made. the diff is about 40mm wider which helps with wheel selections
Posted on: 2003/7/25 5:13
