« 1 (2) 3 »
Re: Custom Dellorto Manifold
From Coondle, WA Australia
nice effort on the fab work. wish I could weld like that. (I tend to be a bird poop welder, unless the planets line up)
Posted on: 2009/1/17 10:26
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Make the runners as long as possible, if your goal is to maximize HP at lower RPMs.
Posted on: 2009/1/17 17:40
So how would the engine behave at the mid-range & high RMP with the carb on these long runners?
Posted on: 2009/1/17 22:22
maybe instead of 100HP, it'll only get 98HP. Just guessing. But that could be the difference between winning or losing a race.
Posted on: 2009/1/17 22:37
From Freo
who says 45's are too big.. a single 45 would work..
the Jap tuners run a pair of 40's on A10 & A12's
and a pair of 45's on A14 & A15's...
Posted on: 2009/1/17 23:06
A15 PSI Project Motor
'72 CB750k,
True that.
Sidedraught's current engine is running twin 45's.
I thought they were rather common!
Posted on: 2009/1/17 23:08
From gold coast QLD.
Yeah,ease up Steve,i had a single 45 with big chokes on the orange KB10 and twin 45's on the sedan and they seemed to go OK
Cheers
Posted on: 2009/1/17 23:13
i'm running twin 40s on my A12 in the sedan and used to run a single 45 on a stock A12 in 120y
Posted on: 2009/1/17 23:36
One 45 on a plenum manifold is nearly equal (as far as airflow) to a Dual 45s on individual runners (no plenum). The Duals have a slight CFM advantage but it's not much.
Now, two 45s on a plenum would be twice the CFM rating ...
Posted on: 2009/1/17 23:50
Here is the sizing:Quote:
* Weber "40" (40mm bore) can fit chokes of 29mm to 36mm
* Weber "45" (45mm bore) can fit chokes of 32mm to 40mm
Bore Sizing
40s are just slightly too big for a stock A12, but for a high HP 8000 RPM engine, either 40s or 45s match up well.
Posted on: 2009/1/18 0:48
« 1 (2) 3 »
