anyone know how my girl should go?
From QLD toowoomba
hey i just rebuily my a12. its got flat top pistons (std's) h891 head oval port ,shaved, lightened flywheel, lumpy cam and is goin to either have duel su's or weber 32/26. ill post how much it cost all up when i get the bill :S hehe do you reckon itll go allright?
Posted on: 2009/2/1 3:15
Re: anyone know how my girl should go?
From Melbourne, Oz
whats it in? 10, 110, 120 ,210 ,310?
Posted on: 2009/2/1 3:17
"I hav achieved wood"
From QLD toowoomba
84 B120 (1200 ute)
Posted on: 2009/2/1 3:40
From Melbourne, Oz
I dont emagine it will be much funn with a load in the tray but should humding when its empty
Posted on: 2009/2/1 3:56
Yep, that engine should be good for around 80HP, quite an upgrade from 69 HP stock, around 15% more power.
Posted on: 2009/2/1 6:02
From QLD toowoomba
just put a 45 thou lift race cam in it... it starts to get power at 3000rpm... then she HOOKS! omg now to get the exhaust system done and put the 32/36 weber on her... and shes better than a gx engine now!
Posted on: 2009/3/17 5:17
84 Datto 1200 ute. flat top pistons lumpy cam h891 shaved head lightened flywheel
From Sydney
Thats a bold statement.GX engines are rather good out of the box for a factory item.
Also to take advantage of your "race Cam", the engine would want to be rather top end spec. e.g induction, head work, compression, spark and exhaust. Typically "Race" cams come on around 5000+ and are peaky. Gearbox ratios would also need to be close to take advantage of the short power band and not land you in a hole on the change of gear.
If the power kicks in around 3000+, sounds like more of a 72 - 74 degree FIA datsun rally grind, much better for pull [torque] out of slow corners at lower RPM's
Best of luck with it.
Posted on: 2009/3/17 6:00
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From QLD toowoomba
update on my 1200... got tuned extractors to a 2inch exhaust to a muffler... its way 2 loud so im going 2 have 2 put a hot dog on her. she has twin dellorto's dhla 40's on a redline manifold. got double valve springs in her now but it keeps blowing the fuse in the voltage regulator at around 7000 rpm so that's annoying. oh the cams a 140 grind. all i gotta do now is get the head ported and polished fairly large to accommodate for the cam's high reving power.
Posted on: 2009/8/19 3:00
