which flyweel to use
From tasmania
putting in an l18 I have an L18 and a l16 flywheel which one to use .light one or heavy one
Posted on: 2009/2/1 6:20
Re: which flyweel to use
light one
Posted on: 2009/2/1 6:23
From Melbourne, Oz
witch will probly still be heaveyer then you need if it's going into a 1000?
Posted on: 2009/2/1 6:28
"I hav achieved wood"
From tasmania
motor is going into a 1200 sedan
Posted on: 2009/2/1 7:55
l 16 one if you have the clutch and pressure plate to match
Posted on: 2009/2/1 10:33
From pooraka,,adelaide
Hey just check they r both the same ay cause I thought a series ones were all the same but then I found this
http://datsun1200.com/modules/nsectio ... p?op=viewarticle&artid=13
I think they're thinner so ya needa longer bearing might b same in ur case. . .
Posted on: 2009/2/1 14:32
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
