« 1 2 (3)
Re: Turbo A15 pistons from factory
From Adelaide
I've run an A15 crank in an A14 so assume it would not be a problem, but correct me if I'm wrong. I think you would have to re-bore for the new pistons, well I would. No point boosting up a tired or worn engine.
Posted on: 2009/2/22 2:45
To increase speed, add lightness.
From Griffith
No offense to everyone else replying to the thread you all have valid points
but SRB310 has had experience with doing this and it has worked ,honestly forgies are way to expensive cost price is around 600 to 700 and they have to be custom made
if you can get away with a turbo motor pistons fitting why not it would be more cost effective and in the end work
as you can see in the pic even if they were shaved look at the amount of dish on there more than enough
by the way SRB310 is that the heat proof coating stuff on your piston
Posted on: 2009/2/22 7:07
From Christchurch NZ
the pages in the links in the 1st post of this thread wont load for me.
The E series pistons don't fit an A15, so they aren't too much use to me.
Posted on: 2009/2/22 8:33
Forced Induction!
From newcastle, NSW
I couldn't get the buggers to open up either?? can someone post up a pic of the pistons?
Posted on: 2009/2/22 9:22
From Griffith
I was just looking at the acl website and the a15 and e15t pistons are almost identical the only difference i could find was the comp Height wich was bout 3mm ( does this mean they might stick out of the block a bit which u could probably shave of)
and the ring groove width was a bit thicker on the e15 pistons , so y is it so hard for them to fit ?
Posted on: 2009/2/22 11:20
From Adelaide
^^^ Is that because they protrude from the block or for other reasons? I've never actually had an A15 block, but seeing as the crank fits an A14 I just assumed they were basically the same.. Interested to know.
dat82: No heat treating went on. At that stage all that had been done to them was balancing. Head work had been done and obviously this affects the compression, but from memory it was 8:1 or a touch higher.
The motor was prepped by Barry at Datsport. I know he deals with mostly 1600s these days but am sure he would field a few questions on the subject for you if needed..
Posted on: 2009/2/22 11:38
« 1 2 (3)
