wHICH eNGINE oIL and Kms RECOMENDED ?
From Sri Lanka
Hi Guys
Please tell me which count of kms are recomended to run between 2 oil changes ? Car Manufacturer or Lubricant Manufacturer ?which type are you using for your's datsun here we have Caltex, Delo, Havoline,Mobil, IOC etc which one gives the maximum KMS and how much is that ?
Thanks
Regards
Sumith
Posted on: 2009/2/23 11:55
Re: wHICH eNGINE oIL and Kms RECOMENDED ?
From South Africa, Bloemfontein
Towndriving service it every 8000km.
Lots of freeway driving, every 10 000km.
The oils you mentioned are all good oils.
Just use a good quality mineral oil and don't mix different oil brands. Stick to the one oil that you decide to use. Mixing different oil brands creates sludge in a engine.
Is your engine used or going to be a new reconditioned unit?
Posted on: 2009/2/23 13:48
1977 Datsun 1200GX
Yes, agreed. Any quality brand may be used.
Synthetic oils costs 3x or more, but can last 3x or more longer. They are not any better for a street car except for that fact.
I use many different regular oil brands, and mix them. I've had no sludge problems over the last 25 years. To avoid debate on this topic, drain the old oil out, and replace with 3 liters of new oil (all three liters the same brand). I have no problems with that recommendation.
They say you should not mix regular oil with synthetic oil.
Posted on: 2009/2/23 22:53
From Melbourne, Australia
I service my cars every 5000ks with an oil filter change every 10000ks.
Use a good brand oil and you cant go wrong.
Posted on: 2009/2/24 3:19
From Sri Lanka
Hi 1200GX MAn
I am using the old engine not the reconditioned one, After long time i started driving it, so want to make it less headache and problem and running cool
Thanks
Regards
Sumith
Posted on: 2009/2/24 3:36
If it is a non reconditioned engine, I would just use a good quality mineral oil and stick to the one you choose for the rest of the engine's life.
Change it every 8000km if you do a mix of driving town and highway/freeway.
Posted on: 2009/2/24 7:58
1977 Datsun 1200GX
From Launceston, Tasmania
I change my oil every 5,000 klms
and oil filter every 10,000 klms
and use Castrol GTX2 20w50 and I haven't had an issue with it in all the years I have been using it.
Cheers.
Posted on: 2009/2/24 8:09
Quite a regular
From Canberra, Oz
Same here i service mine with with the oil change every 5000 km and filters etc every 10000km and have never had a problem i use castrol GTX2 20w50
you should be fine with any 20w50 oil as long as it is a known brand and its not expensive either.
What i mean by that is i know theres dodgy people out there ( no offence) that will get the no branded oil just to save money.
Posted on: 2009/2/24 11:47
