Pistons
From Okinawa, Japan
Just took my A14 apart and the pistons are fried. They're 79mm full floating flat-top with valve reliefs. I need to source some but haven't come up with anything yet. I'd prefer forgies but would settle for cast. Anyone know where to look?
Posted on: 2003/7/30 11:53
Re: Pistons
From T'ville
hi , whats wrong with them ?are they all scared up ?
Posted on: 2003/7/30 12:25
Re: Pistons
From Okinawa, Japan
The same edge on all four has started to melt a little. Funny thing is it's on the side opposite the plugs.
Posted on: 2003/7/30 12:47
Re: Pistons
From Okinawa, Japan
Can't hardly see the valve reliefs here but this is on the side of the piston where the round edge of the reliefs point.
Posted on: 2003/7/30 12:56
Re: Pistons
I'd put those pistons back in. You just need to solve your lean/detonation problem so that they don't get worse.
The carbon is totally burned off that side of the piston. Is the engine pinging? Is there a vacuum leak?
Posted on: 2003/7/31 4:15
Re: Pistons
From Okinawa, Japan
I don't know the history of the engine... it's not just the carbon though... it's the metal itself that's being comprimised... Anyone else think I should slap them back in? Cause I'd really love to so I don't end up spending big $$$
Posted on: 2003/7/31 10:13
Re: Pistons
From T'ville
mate i think they look fine, just grab your toothbrush and give the top a bit of scrub , put them in a box and send them to me , because if you dont use 'em i sure can really if you are concerned show 1 to a mechanic and he should have the knowledge as to what you should do
Posted on: 2003/7/31 13:05
