Fuel Sensor doesn't work ?
From Sri Lanka
Hi Guys
My car Fuel Sensor doesn't work, can i fix it by my self if so can any one tell me steps that i have to see and do
Thanks
Regards
Sumith
Posted on: 2009/2/26 3:14
Re: Fuel Sensor doesn't work ?
You can test it your self. It is usually one of three things:
1. Bad 'sender' (sensor) which is in the fuel tank
2. Bad gauge in the dash
3. Bad wiring
Does the Temperature gauge work OK?
Posted on: 2009/2/26 4:29
From Sri Lanka
Hi ddgonzal
Temperature sensor is working fine but not fuel sensor, what adjustment neeeded to be checked from the dash board side ?
Thanks
Regards
Sumith
Posted on: 2009/2/26 7:05
Start with check in the boot, at the fuel tank. This should be very easy with a Sedan.
1. Pull the Fuel sensor wire off at fuel tank
2. Ground/earth the wire
3. Turn IGN switch on and observe gauge:
* Gauge goes to Full. Bad sender. Replace it.
* Gauge still dead. It is not caused by fuel sender. Check for loose wiring, at back of dash, or at dash wiring harness connectors. If you don't spot the problem, remove dash/cluster gauge and test gauge directly.
Posted on: 2009/2/26 7:36
From Sri Lanka
Hi ddgonzal
I have done a wiring job recently i could not fix all the dash board gauge, is it possible for me to fix those gauge wiring by my self, i am not a mechanical person , how is it difficult task or easy task ?
Thanks
Regards
Sumith
Posted on: 2009/2/26 8:10
It is not normally repaired, but instead replaced. I have no experience in trying to fix a bad gauge.
If a wire is broken, you may be able to solder it as a repair.
Posted on: 2009/2/26 8:27
From Sri Lanka
Hi ddgonzal
As you said I checked my Fuel Sensor it is gone, are those available to buy or can i fit another fuel sensor , is it common or datsun specific sensor ?
Thanks
Regards
Sumith
Posted on: 2009/3/3 5:51
It is very specific to B210 sedan. Coupe is probably different.
Posted on: 2009/3/3 5:57
From Charlevoix, MI USA
Sunsmith-
What do you mean fuel sensor is gone? Have you removed it and checked the variable resistor?
Posted on: 2009/3/6 4:28
"from the land of the graceless bumper"
'78 B210GX BREwannabe'
From Sri Lanka
Hi LONGBROW
as ddgonzal said i checked the fuel sensor gauge, as he sais the sensor went to top means bad sensor or loose wire connection
Thanks
Reagrds
sumith
Posted on: 2009/3/6 5:17
