« 1 (2)
Re: Fuel Sensor doesn't work ?
From Charlevoix, MI USA
Ok ...I got confused whether it was the sending unit or gauge that was bad.
If you have determined it is the sending unit and you cannot get another one; it may be worth your time to remove and clean it. It could easilly be stuck,or the float may no longer float. My car had sat for about 15 years before I bought it and the sending unit was covered in rust and varnish. Cleaned it off and she works like a champ.
Posted on: 2009/3/6 17:52
"from the land of the graceless bumper"
'78 B210GX BREwannabe'
From Sri Lanka
Hi Guys
Got it done by my self ,actually that was a broken wire connection with the sensor
Thanks
Regards
Sumith
Posted on: 2009/3/9 7:31
Glad to hear you got it fixed. So there was a loose wire inside the fuel tank on the sender itself?
Posted on: 2009/3/9 7:45
From Sri Lanka
Hi ddgonzal
That was the broken connection in the sender wire
Thanks
Regards
Sumith
Posted on: 2009/3/9 7:53
« 1 (2)
