What Is this Problem ?
From Sri Lanka
Hi Guys
I have a problem that i had before again back, that is when i hold the clutch down to change the Gear, car acceleration increased,
What would be the Case, i had the same problem because the acceleration cable was loose from the connection when i fixed it that was ok, now it is fixed properly again i got the problem , any Idea Please
Thanks
Regards
Sumith
Posted on: 2009/3/16 6:31
Re: What Is this Problem ?
sounds like accelertor cable is sticking or pedal. could also be worn return spring on the carby, allowing the car to keep on accelerating not pulling the throttle arm/lever back to stop flowing petrol.
Could also be overfueling from the fuel passing through the jets if they are seating correctly or a high float level.
Posted on: 2009/3/16 6:56
From Sri Lanka
Hi unfamilia
I also feel the Acceleration padel is very hard to push down , that might be the reason i alos guest so , shall i change my acceleration cable ?
Thanks
Regards
Sumith
Posted on: 2009/3/16 7:02
try it, it can only be trial and error some times, others will say diagnose and repair. to me its the same thing
Posted on: 2009/3/16 11:18
Quite a regular
From pretoria, south africa
have a prob like that you just have to move that where the sleave of the accelration cable is like held move that a bit foward so it has slack do it when the car is running warm because it seems to get tighter and not having that slack it just doesnt pull back far enough and it`l be accelarating quite high... unles it`s another problem, that`s just something i had to play with
Posted on: 2009/3/16 11:26
From pooraka,,adelaide
I had that problem and for me I found out it was my carbie like where the acelerator cable hooks on wen it spins and goes back it doesn't always go right back it had a little notch where it was catching so I think it may have been a blown rubber in it
I changed carbie and it was all fine
And if u lube up ur accelerato cable might b looser and or put a tighter spring on ur carby
Good luck
Posted on: 2009/3/16 15:16
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From Sri Lanka
Hi Guys
I found my throttle cable is properly hooked into the carb, when i start the engine it is starting with higher rpm and gradually reduce it, can anyone post me a clear picture how the throttle cable should be connected to carb ?
THANKS
REGARDS
SUMITH
Posted on: 2009/3/19 5:25
throttle cable to carburetor
Posted on: 2009/3/19 6:01
From Perth WA
also lubrication in the cable is important, and any clamp too tight will also stop it working properly
Posted on: 2009/3/19 6:40
