« 1 2 (3)
Re: coil overs
From brisbane
Hi Rob
Fulcrum were the best value when I was shopping around for coilover sleeves a few years ago.
Regards Matty
Posted on: 2009/3/22 20:53
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: coil overs
From The garage, NZ
Ground control is what I'm using. Alloy however and sit on a perch. Awesome quality, since then have bout some more locally but they are 199US$ for a pair off their site
Posted on: 2009/3/23 19:26
Re: coil overs
From Wagga Wagga, NSW
Ive got a set of coilovers from ground control on the way with eibach springs, they are $335 delviered
Posted on: 2009/3/23 21:08
Re: coil overs
From cranbourne, vic
thats alrite, even with todays fail economy!!!
whats the spec's on the springs your gunna run??
Posted on: 2009/3/27 8:00
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
Re: coil overs
From Cape Town, South Africa
What spring spec's will be good for the B140 Ute with a A15 motor in.
Use of the vehicle will be for Gymkhana in SA.
Posted on: 2009/4/21 12:57
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
« 1 2 (3)
