Which Diff
From Brisbane
Hey guys so the diff went in my 1200 ute today... Still drives but is clunking, so anyways I am after a new diff. The ute is ca18det powered and only has 150ponies and the moment but is only running the standard ecu and 6psi, am planning on running some bigger power numbers in the near future... So I am just after some guidance to which diff to go for? Obviously it has to be able to hold some decent power and I dont want a single wheeler
Cheers
Dan
Posted on: 2009/3/28 6:09
If you want more inches, stroke it
Re: Which Diff
From Melbourne, Oz
what year is your ute?
Posted on: 2009/3/28 6:27
"I hav achieved wood"
Re: Which Diff
The horsepower doesn't matter -- it matter how much torque you have. Of course generally when you have more HP you also have more torque, but it depends on the RPM.
A 1.8 turbo with 150HP probably has what? Less than 200 lb. ft torque?
Strength of Differential -- Torque Rating
diff inches max. torque capacity
H145 5.71 ~100 lb. ft.
H150 5.91 ~125 lb. ft.
H165 6.50 ~225 lb. ft.
H190 7.49 ~285 lb. ft.
R200 7.88 ~300 lb. ft.
Ford 8 8.00 ~325 lb. ft.
Ford 8.8 8.80 ~500 lb. ft.
Ford 9 9.00 ~600 lb. ft.
See Rear Axle Swaps
A Datsun 411 H165 or Datsun 320 H190 axle assembly can be fitted on the cheap. They are narrower than a 1200 assembly if I recall correctly. See Diff Widths
Posted on: 2009/3/28 6:29
Re: Which Diff
From Brisbane
Its a 1980... And I'll dig out the dyno report to see how much torque it has
Posted on: 2009/3/28 7:25
Re: Which Diff
From Brisbane
Ok so i dug out the report and it dosnt say anything about how much torque it has....
Posted on: 2009/3/29 7:05
Re: Which Diff
From brisbane, QLD
hey mate im doing a ca18det conversion to my ute and after talking to a couple of diff shops i going the r31 skyline lsd. I live in bribane and im getting it shortened and rebult by a guy in mt cotton one..
Posted on: 2009/3/29 10:19
Re: Which Diff
From Brisbane
Hey mate can you please give me a little more info on the setup you are going for? You going to use the skyline brakes ect... And any idea of the cost? PM me if you prefer...
Posted on: 2009/3/29 12:01
Re: Which Diff
From Geelong, Vic
R31 skyline diff, same basic diff as what you find in vn-vs commodores
needs to be shortened 155mm to be stock 1200 width, use the original short axle as the new long axle and you only have to get the original long axle cut down
yes you use the stock r31 rear disc brakes
can get ratios from 3.08-4.11
LSDs are the same as the ones used in v8 commodores
can buy a bolt in unit from maddat for around $2500
think i got quoted around $1000 to get an r31 diff shortened and new mounts welded on
wreckers want around $200 for a complete r31 diff with open centre, $350-400 for one with an LSD
ive got one cut down, just need to get around to welding mounts onto it and getting the axle cut down. but i'll be wanting around $1000 for it once its done
its just an open centre with 3.7 gears
Posted on: 2009/3/29 12:16
Re: Which Diff
From brisbane, QLD
pm sent
hope it helps..
Posted on: 2009/3/29 12:46
Clint at Profile Autosports and tuning for all mechanical needs and dyno tuning Brisbane..
current rides..
02 hilux daily.
ca18det 1200 ute
Re: Which Diff
From Brisbane
Thanks for that mate, will definatly look into it
Posted on: 2009/3/29 13:44
