« 1 (2)
Re: Rezlo's A15 build & B110 Marque race rebuild.
From South Africa, Bloemfontein
Hi Rezlo.
I am also from South Africa and if you look at my car picture you will see my car is exactly the same colour as yours.
Can you post up a pic of your wheels?
They seem to look asif they have a very wide tread.
Posted on: 2009/4/3 11:10
1977 Datsun 1200GX
Hi Rezlo.
They seem to look as if they have a very wide tread.
Great build by the way. I completely love what you did with the car and especially the engine.
Posted on: 2009/4/3 11:25
1977 Datsun 1200GX
From Freo
don't think they would,
the two pipes side by side will go a bit close to the Idler arm and bell housing..
Posted on: 2009/4/3 13:33
A15 PSI Project Motor
'72 CB750k,
From South Africa
1200GX man, dont you remember emailing me a few months ago? :-p they 185/?/13, cant quite remember the ratio, rims are pretty wide, I really battled to get them in there nice, clear the front calipers by 3mm
Little laugh, one of my customers said I should fit my silvia's turbo to the A-series, might spool it at 18 000rpm
jpg  PICT8313 (Medium).JPG (37.45 KB)
9082_49d6128d0bb2d.jpg 443X600 px
Posted on: 2009/4/3 14:44
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
From South Africa
Now for suspension:
because it has to stay similar to stock I thought I would start off mild and see how I like it, having a car that is to taught doesnt work well on our track so I thought I would go along with the OE theme,
Rear leaf springs had one more spring added and the whole lot were re-tempered and new bushings
Front got the royal treatment:
New inner tie rods
New outer tie rods
New drag link
New Pitman arm
New ball joints
New tension rod bushings
New control arm bushings
New swaybar bushings
New shock's
Retempered stock springs
Modified Ute strut tubes for -.5deg camber
New ATE brake disks/rotors (same size as the origional 1200's
New ATE pads
Rebuilt Ute calipers (much better than the 1200's)
ATE super blue brake fluid
Rebuild master cyl (I like non assisted brakes
Steering box drained, flushed, new oil, set
Good thing is my car has a 19.5mm front swaybar, no idea why its so thick but it doesnt apear to ever have been changed (obviously it was)
Car handles amazingly well for basicaly stock, I was able to hold all the faster cars off around the corners including the 911. I might put a tiny bit more camber in the front but im not out to change much as its handeling is very neutral now and "easy" to use.
here are some pics, suspension work made the biggest mess my workshop has ever seen.
jpg  Stock.JPG (54.32 KB)
9082_49d615200f045.jpg 800X600 px
jpg  Late year ute.JPG (37.79 KB)
9082_49d615303e723.jpg 800X600 px
jpg  Mess.JPG (70.62 KB)
9082_49d6154485e1b.jpg 800X600 px
jpg  Seting up.JPG (64.56 KB)
9082_49d61553975f7.jpg 800X600 px
Posted on: 2009/4/3 14:55
'07 Hilux - Tow car
Quote "1200GX man, dont you remember emailing me a few months ago?"
Oops, I now remember. Great to now finally see the build. Keep the pic coming. It looks fantastic.
I think you have the GX swaybar in. That is why it is so thick.
Posted on: 2009/4/6 8:46
1977 Datsun 1200GX
From Johannesburg-South Africa
can you please tell us about the pistons you used and what machining was needed on the pistons and block
Posted on: 2009/12/8 14:31
From NW Sydney
This car has got me inspired! I really like the fact that simple, affordable mods have helped a near-stock car to outperform so many 'sports' cars
What sort of comments to you get/overhear in the pits?
Posted on: 2010/5/27 0:11
SR20DET 1971 Datsun Bluebird 1800SSS Coupe - 11.58 @ 122.40 MPH GT2871R PLMS NIStune
Historic 1971 Datsun 1600 Wagon - L series nostalgia
Historic 1967 Datsun 1000 Wagon - A series resto
From Pretoria SA
Good day to you, i read you artical and i'm impressed. i am clearly new on this site but not new to datsuns, they are strong and trustworthy, anyway i also stay in sa, i have a 1983 datsun bakkie and have some modds done to it. BEST of luck to you!! Kick some 911 ass! im intreaged keep me posted
Posted on: 2010/5/27 10:24
« 1 (2)
