« 1 (2)
Re: urgent help required- Dellow 5-speed problem
From sydney australia
not much help for you at the moment, but a friend of mine got one of the first dellow conversions & one of the things he doubted was this part of the conversion. He got a sleeve machined up to take a standard Datsun throwout bearing & arm. Unfortunately Ron passed away a few years ago, & his Ute has disappeared as his ex-wife was still listed in his will & she sold it off. Typical that it'd happen just at the worst possible time. A call to Dellow on Tuesday might be the go.
Posted on: 2009/4/10 6:07
From newcastle, NSW
Yeah it couldn't have happened at a worst possible time! the car was all finished and ready to go on the trailer, but mind you, it was lucky i took it around the block for a spin before i put it on the trailer, i wouldn't have even made it out of pitlane, so i would've went all the way to QLD for basically nothing. But i'm a firm beliver that things happen for a reason! it was never meant to be obviously! Oh well.............. You get that!
I'll definatly give Dellow a call next week to ask for their advice. I have never heard of a thrust bearing wearing out so quick, particulary the standard steel type that the datsun gearboxes have. The only thing i can think the problem being is the datsun pressure plate that i used? maybe that is what chewing the toyota unit?
Not exactly sure? its got me stumped! i'll have to have a look when i take it apart in the next couple of days.
Posted on: 2009/4/10 8:08
From windsor, sydney
stevo you must check that the bellhousing is square to the block and the spigot hole in the bellhousing is concentric to the crankshaft , do this with a dial indicator stuck on the flywheel and turn the motor over by hand , sorry to let the wind out of your sales but i have had some bad results with dellow stuff before , the only fix in my instance was to completly remachine the casting myself as dellows machining was wrong.
Posted on: 2009/4/11 5:18
From sydney
This box had been completely overhauled, and had been working without issue in a competitive race car since the rebuild, I hope you can find the source of the problem.
Posted on: 2009/4/11 11:21
From Perth
I always thought mine used a modified Datsun carrier and bearing on the modified Toyota spigot.
I recall boring out the carrier and machining down the spigot to use the Datsun carrier and bearing
Can't check though
Am 10 000 miles from the gearbox
Posted on: 2009/4/15 18:26
« 1 (2)
