« 1 (2)
Re: want to install dcoe40 into my A15...
From Sydney
backfire /popping sound usually indicates a lean mixture condition...
Posted on: 2009/4/10 2:05
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Kuala Lumpur, Malaysia
i see...i still using the mechanical pump..do i have to use an electric pump to support my dcoes...so my tuning n jetting is not correct is it??need to make it richer a bit??
Posted on: 2009/4/10 6:22
Face Your Demons
From Sydney
I would check the float level on both carbs, also the synchronisation between both carbs. The std mechanical pump is up to the job. .
Posted on: 2009/4/10 7:24
1970 KB10 Coupe
S13 caliper b...
From South Africa
Benny, what do you think that 450ml/minute would support power wise on a build A-series with 40's? some of our tracks have a hell of a long main straight (over 1.5km... I automaticaly went to a holley pump and holley 1-4psi regulator but I would not mind going back to mechanical because the sound of a holley makes a person mental when driving round town.
Posted on: 2009/4/10 8:23
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
From Sydney
Very good friend of mine became the Australian offroad buggy champion [mid nineties from memory] with a very hot A15 on twin 45's fed by a mechanical fuel pump. The pump is up to the job. Saying that though, i also run a holley blue in my track car.
benny
Posted on: 2009/4/10 23:30
1970 KB10 Coupe
S13 caliper b...
From South-Africa,Pretoria
Popping sound has also been a problem on my lower range, Is it a to lean setup ?
Posted on: 2009/4/11 7:25
1993 Nissan Bakkie - Rebuilding A15
www.spitronics.co.za
Keep it OldSchool, keep it Datsun
Some can afford the legends, other try to revive them.
From T'ville
do your 40's use a spring to hold the chokes in place. this where i had problems, the chokes would move around and loose vacum/venturi effect and ruuning lean. make sure all parts are in good order.
Posted on: 2009/4/12 13:24
From South Africa
Turn the idle mixtures out 1/2 a turn each, popping is usualy a sign its lean on the idle circuit
Posted on: 2009/4/12 17:57
'07 Hilux - Tow car
« 1 (2)
