Problems locking doors ?
From Murray Bridge, SA
hey everyone, im just in need of abit of help, my front doors on my sedan wont lock after ive put them back on. they look aligned alright but arnt perfect, will this affect its ability to lock? theres just know give in the knob, wont push down at all.
can any 1 help?
cheers
Posted on: 2009/4/29 14:35
Cars:
1973 Datsun 1200 sedan (Project)
19?? Datsun 1200 sedan (Parts Car)
A12 crankin
Re: Problems locking doors ?
Your lock mechanisms are probably a little worn or bent (not the barrel but the mechanisms).
This is a common thing (from my experience) in 1200's.
You really need to pull the door cards off and have a real good look at what is supposed to line up where.
Have you go a manual? They are pretty helpful in terms of looking at what you are up against.
Posted on: 2009/4/29 14:53
From Christchurch NZ
my mates 1200 had the same problem recently. He had a key made for his door lock, 'cos his car came with none. The key would turn, but it wouldn't quite pull the knob down enough to lock it. In the end all it needed was the rod from the back of the barrel to the latch to be bent more or straightened out more. (I can't remember which) Either way it was an easy fix.
Posted on: 2009/5/1 9:22
Forced Induction!
Thanks for that info. My ute has the exact same problem (key will turn, but it won't quite pull the knob down enough to lock it).
Posted on: 2009/5/2 3:49
From hervey bay queensland
i had this problem when putting my doors back on , you can adjust it on the inside of your door you will see the thread just above the door handle on the inside there is a nut on it and you adjust that and i have also found that a bit of wd40 spray works wonders as well.
Posted on: 2009/5/2 6:07
made a new, shorter rod out of a coathanger for the boot on the wagon the other day...now it opens and closes a treat!
Posted on: 2009/5/2 8:03
