Browsing this Thread:
1 Anonymous Users
Re: help needed, 63A transmission diagnosis- lost R, 2nd ,& 4th all at same time |
Quote: retrorally wrote: I thought that Revhead was going to say, "theres to much Wig in the Wig Wag"
boom boom tssh. Got me there. Funnily enough at work we have a simular thing in the Murchilargo box that is called a wig wag. That is why I call it so...
Posted on: 2009/4/29 10:32
Not too shy to talk
From Los Angeles California
Is it possible to pop the rear extension assembly off with out having to dismantle the front?
The manual shows a longer complete disassembly procedure that seems better to avoid in this case...
Posted on: 2009/4/30 21:18
Not too shy to talk
I might be able to afford the shipping on the finger, you may not want to pay the shipping on the tranny from Los Angeles California 90026!
How much to liberate the finger mate?
Posted on: 2009/5/1 7:06
From Perth WA AUS
I had the same problem in my old 1200 rally car, it happened pretty suddenly. I lost 1st & 3rd gears not sure about reverse, anyway I lined up the gear lever with first gear and gave it a good whack, it went in and I kept driving. I can't recomend doing this but it worked for me & lasted another 6 months.
Posted on: 2009/5/1 7:35
Datsun 1200 2Dr sedan.
From Christchurch NZ
I'm not sure about shipping. But I have a family member who is going to california in june. Pull your gearbox down, and if it is what you need, I could get them to send it from over there. That would be a massive cost saving. I've already got them picking up loads of treasure that I've had sent to the people they'll be staying with.
Posted on: 2009/5/1 9:15
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
From Charlevoix, MI USA
Quote: B2Slow wrote: Is it possible to pop the rear extension assembly off with out having to dismantle the front?
Yes. What manual do you have?
Posted on: 2009/5/1 18:02
"from the land of the graceless bumper" '78 B210GX BREwannabe'
Not too shy to talk
I have a 76 B210 manual, so i'm looking at a 4spd tranny... i'd have to get 77 or 78 manual for the 63A 5spd but they seem structurally similar... maybe someone out there has an image and instructions for the 63A 5spd rear extension they might post? could also check the library.
Posted on: 2009/5/1 19:59
Besides arrangement of gears, the Striker arm is the main difference in the 60 and 63 series. Essentially the same concept as the 4sp though. I’ll get the 63a chapter scanned and sent to you and get it posted here somewhere-Maybe with TnShow’s 60a 5sp. When I scan I will highlight to steps and add an adjustment in the reassembly of the rear housing that will save you a lot of trouble, believe me I learned the hard way.
Posted on: 2009/5/1 23:41
Not too shy to talk
Excellent. Thanks so much LONGBROW. Pulling tranny this wkend.
Posted on: 2009/5/2 0:22
Not too shy to talk
Quote: levey wrote: I had the same problem in my old 1200 rally car, it happened pretty suddenly. I lost 1st & 3rd gears not sure about reverse, anyway I lined up the gear lever with first gear and gave it a good whack, it went in and I kept driving. I can't recomend doing this but it worked for me & lasted another 6 months.
Levey, Thanks for your suggestion! I WHACKED it with my 4lb urethane clown mallet while in the reverse position and got Rev, 2nd, & 4th to come back... they are a little crunchy but perhaps I'll get another 6 months out of it... Maybe we should start a Ghetto Technology thread for this type of sophisticated fix
Posted on: 2009/5/2 18:36
