ca18det gearbox
From gold coast
hey all just need some info on my gearbox..what is the oil capicity? its a red import box if that means anything and also what oils would you recomend? im a castrol man
Posted on: 2009/5/2 7:25
Re: ca18det gearbox
From perth
castrol website
Posted on: 2009/5/2 10:05
Re: ca18det gearbox
From gold coast
ok done change all sweet but the seal where the tail sharft comes out of the gearbox is leaking?? any help be great...big job?
Posted on: 2009/5/3 12:43
Re: ca18det gearbox
From Sydney, Australia
If the tailshaft is slotted into the end of the gearbox, then you need to go get another seal from nissan.
Posted on: 2009/5/3 13:14
Re: ca18det gearbox
From Mandurah, Western Australia
The seal in the end of the box can be changed. Just drop the tail shaft out and pull the old seal out and tap the new one into place. Drain the oil first.
How much oil did the box take?
Posted on: 2009/5/3 13:55
Re: ca18det gearbox
From gold coast
ok so ill be able to do it myself?...i put 2.5ltrs in the box
Posted on: 2009/5/4 3:26
Re: ca18det gearbox
From Rocky Queensland
just fill it to the top plug. when it lightly leaks out of that its full.
Posted on: 2009/5/4 6:40
